I have a 1994 Mit 3000gt double overhead cam 24v engine I am in search of the location of the fuel pump relay
Mar 19, 2010 at 12:27 PM
✓Experienced Mechanic
Fuel Pump Relay
Control Relay
Oct 11, 2017 at 3:11 AM
STROSNIDERA35
MEMBER
1 POST
Picture if possible also i need to know what each fuse is for and where they are located pic .
Wont turn over ran out of gas a couple days before thought sit had something to with the fuel pump also maybe if a fuse is broke or missing or need a picture if you could possible appreciate it very much
May 26, 2020 at 4:10 AM
(Merged)
The fuel pump receives voltage supply from Multi-Point Injection (MPI) control relay. Here is a guide to help you check out the relay and fuses.
