1994 Mitsubishi 3000GT Fuel Pump has no electrical to it
1994 MITSUBISHI 3000GT
167,900 MILES • 6 CYL • FWD • AUTOMATIC
RJAYNES
Had issue with the car quitting like it was out of gas. the fuel pump was changed, however there is no electric power to the pump.
Looked for fuse could not find one.
looked for fuel pump relay could not find it. (According to the part shape and plug end for the replacement )4part
Went to auto parts dealer and pulled up all the components listed for this vehicle, they included relay
shut off switch and the pump.
Tested the new pump it works, the relayy the y had for the fuel does not match anything on this car.
there is no emergency reset button on this car.
still no power to the fuel pump
Great little vehicle just quit running
Jul 23, 2010 at 3:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no fuel pump specific relay, but the MFI Control Relay has the fuel pump on its circuit and will need tested. also make certain that the anti theft system is not prevent power to fuel pump. the fuse will be #12 (20 amp, yellow) in the power distribution center.
Jul 23, 2010 at 3:52 PM
