1994 Mitsubishi 3000GT antifreeze problem
113,000 MILES • V8 • FWD • AUTOMATIC
LTTLO87
My car has a really bad leak in it. It looks like it's dripping right behind the pulley that is right behind the driver side wheel. I'll go through about a gallon of antifreeze in about two or three days. I was just wondering if you could tell me where the leak could be and about how much you think it would cost to fix.
Jan 21, 2009 at 9:11 AM
  • 31,937 POSTS
Hi there,
You will need to get this pressure tested and inspected by a mechanic to confirm the diagnosis, but if it is a water pump you will be looking at around $150.00 for a new pump
$ 22.00 for a thermostat
$140.00 for a timing belt if require
nd coolant and any other hoses that may need replacing , the labour would be in the order of about 6 Hrs to do the pump, thermostat and timing belt.
( all costs and labour times taken from Mitchell 1 )
mark (mhpautos)
Jan 21, 2009 at 9:47 PM
