1993 Mitsubishi 3000GT Slave Cylinder
120,000 MILES • 6 CYL • FWD • MANUAL
DONPLA1
i've been fighting with this car since i bought it and now i can't seem to get the clutch bleed right. I've opened the bleed screw and pumped out the fluid but still am not getting any compression to my clutch pedal. got any advice?
May 12, 2009 at 3:43 AM
DOCFIXIT
  • 18,828 POSTS
was clutch master and or slave replaced? Put a tube on bleeder place other end into a contaner of fluid. Then pump pedal until all air is out.
May 12, 2009 at 4:06 AM
DONPLA1
i tryed that and it still seems to be sucking air in from some where and i replaced the slave cylinder but havent replaced the master cylinder yet but i'm about 90% sure that its not the master cylinder
May 15, 2009 at 8:08 AM
DOCFIXIT
  • 18,828 POSTS
If not master then where is air getting in. In my many years of repair and 12yrs at Mitsu always replace master and slave as a set.
May 15, 2009 at 8:13 AM
DONPLA1
ya thats how ive done every other clutch...but i onjly replaced the one because i questioned the mechanics judgment and turn out i was right. Sum how the "brand new" clutch kit the guy had installed the week before i bought the car had the pressure plate burn up in it. Not sure how or why but i guess its time for sum wrench time of my own
May 20, 2009 at 2:01 PM
DOCFIXIT
  • 18,828 POSTS
Sound like they put a disc in and nothing else your right if you want it done right do it yourself. Some people in my profession give us all a bad rep.
May 21, 2009 at 2:57 AM
