1991 Mitsubishi 3000GT
85,000 MILES • 6 CYL • AWD • MANUAL
WAZZA275
hi, my engine is making a rattly noise when its running weather stationary or driving but this noise goes away when i press the clutch down,its the twin turbo model if this helps,also i have the pop up head lights but only one pops up and goes down the other i can do manually i was told this may be a relay as they run seperate from each other, but have no idea where they are. thanks for your time, and any help would be most appreciated.
Apr 6, 2010 at 4:33 AM
  • 75,988 POSTS
Sounds like there's a problem within the clutch assembly
Apr 6, 2010 at 5:38 AM
