Missing vacuum hose
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
GOOCH8318
There are two ports located in front top of engine, one terminates to the PVC and the bottom one is missing. There is just an open port sucking air in. I am stymied. Any clues?
Feb 13, 2018 at 8:18 AM
CARADIODOC
  • 34,414 POSTS
There is a vacuum hose routing diagram on the emissions sticker under the hood, that is correct for your year and optional equipment. If there is a hose that is disconnected, the diagram will show what it goes to. If no hose is shown, there was a square foam filter on that port.
Feb 13, 2018 at 8:50 AM
GOOCH8318
One of the hoses was connected to a closed port located on the right side of the manifold. That emissions diagram located under the hood was very valuable to me. After placing the hoses in the correct position. I was able to clear the idle code and the check engine light went out. The vehicle runs great.
Sincerely,
George Gooch
Feb 17, 2018 at 6:36 AM
CARADIODOC
  • 34,414 POSTS
Happy to hear you solved it. Come back to see me again.
Feb 17, 2018 at 10:39 AM
