Runs rough at idle and under power putts and misses, however at top speed runs fine.
Dec 20, 2017 at 1:51 AM
✓Experienced Mechanic
If the engine has a misfire, you need to first check for trouble codes using a scanner. It should identify which cylinder is the problem and then you can focus on that.
