Missing under load
246 MILES • 1.5L • 4 CYL • 2WD • MANUAL
HODAX64
Runs rough at idle and under power putts and misses, however at top speed runs fine.
Dec 20, 2017 at 1:51 AM
  • 110,248 POSTS
If the engine has a misfire, you need to first check for trouble codes using a scanner. It should identify which cylinder is the problem and then you can focus on that.
Here is a video showing how to get the codes:
https://www.youtube.com/watch?v=YV3TRZwer8k
Let me know what you find.
Dec 20, 2017 at 12:06 PM
