Code p1633, missing and idling too high
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
SHERRYMC1985
When first crank car up it idles too high. Going down road pushing the accelerator it bogs down and pops and don't won't to go but let off the accelerator it goes on its own. Check engine light and airbag light is on. Can't see the mileage screen because it does not work. It is missing very badly. Code p1633 on My obd2 is popping up.My husband is a mechanic and he has replaced a bunch of stuff and we have gone over the entire car trying to figure out this issue. Please help.
May 15, 2020 at 2:20 AM
Is the P1633 the only code in the system? It seems unlikely that if the engine light is on and runs poorly that it will only have a keep alive memory code.
This light will turn on due to the code but unless the PCM is damaged causing the light and the running issue, we need a little more to go on.
So let's start with checking fuel pressure while running. Then check for a vacuum leak.
Here are some guides that will help with this. Let me know what you find and we can go from there. Thanks
May 15, 2020 at 2:36 AM
Good morning,
Can you list what he has replaced?
https://www.2carpros.com/articles/engine-idles-too-high
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
https://www.2carpros.com/articles/engine-backfires-while-running
Is 1633 the only code?
This code is for the keep alive memory for the PCM. Make sure he checks all the fuses for power on both sides. This is not a visual test, it is a power test.
QB: DTCs P0603 or P1633: Keep Alive Power
QB: Introduction See: Computers and Control Systems > Pinpoint Tests > QB: DTCs P0603 or P1633: Keep Alive Power - Introduction
QB1 CHECK THE 12-VOLT BATTERY TERMINALS
Note:If KAPWR is interrupted to the PCM when a breakout box is installed or the battery is disconnected, DTC P0603/P1605 can be generated on the first power-up.
INSPECT the 12-volt battery cables for loose connections and for corrosion.
Are the 12-volt battery terminal connections in good condition?
KEY OFF.
GO to QB2
Repair any concerns found.
QB2 INSPECT THE ENGINE COMPARTMENT FOR PROPER WIRE ROUTING
INSPECT the Electronic Engine Control (EC) system wiring for proper wire routing.
Check the wiring routing to establish if any of the electrical connectors are being stressed due to poorly routed wiring. If necessary re-route the wiring and secure.
Visually inspect wiring and connectors.
Are there any wiring problems?
Repair as necessary.
GO to QB3
QB3 CHECK KEEP ALIVE POWER (KAPWR) TO THE PCM
PCM connector disconnected.
Measure the voltage between:
While observing the multimeter, grasp the Electronic EC harness and wiggle, shake or bend a small section while working from the battery to the PCM.
Is the voltage less than 10.5 V?
ISOLATE the fault and REPAIR as necessary.
GO to QB4
QB4 CHECK FOR A REPEAT OF THE DTC
PCM connector connected.
Clear all DTCs that may have been caused by the PCM disconnect.
Test drive the vehicle and allow the engine to reach normal operating temperature.
CHECK Self-Test DTCs:
Are DTCs P0603 or P1633 present?
INSTALL a new PCM.
REFER to Section 2, Flash Electrically Eraseable Programmable Read Only Memory - Flash EEPROM See: Computers and Control Systems > Programming and Relearning > Flash Electrically Eraseable Programmable Read Only Memory - Flash EEPROM
Unable to duplicate or identify the fault at this time.
REFER to Section 4, Diagnostic Trouble Code (DTC) Description for possible causes and additional DTC description information.
GO to Z1 See: Computers and Control Systems > Diagnostic Trouble Code Tests and Associated Procedures > Z: Intermittent - Pinpoint Test
May 15, 2020 at 2:46 AM
