Missing an geting hot
2,475,826 MILES • 5.7L • V8 • 2WD • AUTOMATIC
LMFAOJJ
Thermostat stuck the truck got hot theres no water in the oil ive pulled all the plugs no water there its missing an geting hot in about 5 mins with the thermostat out
Jan 15, 2016 at 4:46 AM
it sounds like either you have a clogged radiator or you have a bad head gasket. you can get a chemical kit at a parts store to verify the head gasket
Jan 15, 2016 at 7:31 AM
LMFAOJJ
I stared tairing down to the head gasket an took the valve cover off an found a rocket arm off the push rod with there being no water in the oil or on the piston would the head gasket be ok
Jan 17, 2016 at 1:45 AM
why would you do this without verifying it is bad???
a rocker arm off will not cause the overheating
Jan 17, 2016 at 8:13 AM
