Missing a Fuse for " Air Pmp 3.4L"
1996 BUICK REGAL
117,000 MILES • 3.8L • AUTOMATIC
REBIRTH98GH
  • 6 POSTS
Went to check out the fuse for update on this 1996 Buick Regal. Under the hood. Passenger side. No fuze is there? Nothing. Not even a plug. No connection slot for this fuse? Ive seen 2 different Diagram for that slot. One has it and one doesn't? My box has a picture of where it should be. Its not. Why is that?
Aug 24, 2025 at 2:34 PM
MECHTRIX
  • 526 POSTS
So if they made the car two different ways maybe yours was the one without
One way you can find out is with your vin
Aug 24, 2025 at 3:10 PM
MECHTRIX
  • 526 POSTS
Can you post a photo or the area where the part is were talking about ? I can look it up for you
Aug 24, 2025 at 3:12 PM
REBIRTH98GH
  • 6 POSTS
Here you go. Appreciate it.
Thank you
Aug 24, 2025 at 3:24 PM
MECHTRIX
  • 526 POSTS
When you look down inside if the fuze terminal do you see anything or is it empty? Or a blank receptical
Aug 24, 2025 at 3:46 PM
MECHTRIX
  • 526 POSTS
Also are you saying you do have the device but not the fuze for the device ? If you dint have the device then of coarse no need for a fuze ..in other worlds different models use one and others don't every manufacturer does this ..they have different vehicles with the same fuze pannels they just leave some blank if they're not needed
Aug 24, 2025 at 3:51 PM
MECHTRIX
  • 526 POSTS
Whats the component you think you have that needs a fuze designation? In otherworldly what would this fuze go to ..thats missing ..this is vary comon
Aug 24, 2025 at 3:53 PM
MECHTRIX
  • 526 POSTS
Can you post a photo of the part in question thats missing a fuze
Aug 24, 2025 at 4:00 PM
