Dies while idling
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BARBARA1963
  • 99 POSTS
This car was running hot, leaking at the thermostat. I replaced the thermostat, changed the plugs and wires. Now it dies while idling. I scanned it and it showed no codes. What could be causing it to die at idle?
Aug 6, 2016 at 5:54 AM
WRENCHTECH
  • 20,758 POSTS
Did you disconnect the battery at any time when performing this work?
Aug 6, 2016 at 7:35 AM
BARBARA1963
  • 99 POSTS
No I did not, but do I need to cross the cables to reset computer or what?
Aug 6, 2016 at 7:39 AM
WRENCHTECH
  • 20,758 POSTS
Check for any vacuum hoses you may have left off on reassembly.
Aug 6, 2016 at 7:41 AM
BARBARA1963
  • 99 POSTS
Okay, I will look for a unconnected vacuum hose, let u know something later, thanks wrenchtech.
Aug 6, 2016 at 7:47 AM
BARBARA1963
  • 99 POSTS
There are no vacuum hoses un plugged and timing chain is on all points but it still sputters like its missing
Aug 9, 2016 at 3:42 AM
WRENCHTECH
  • 20,758 POSTS
If it wasn't missing before you worked on it, you need to go back over everything you did. Something you did triggered this.
Aug 9, 2016 at 5:59 AM
BARBARA1963
  • 99 POSTS
Got it,the timing pulley moved when I put belt on, thanks for your help
Aug 9, 2016 at 7:25 AM
WRENCHTECH
  • 20,758 POSTS
What? Are we talking about a timing belt or a drive belt? There are no external pulleys that have anything to do with timing.
Aug 9, 2016 at 7:37 AM
