Flashing service engine message and engine misfires when driving up hill
176,345 MILES • 5.4L • 2WD • AUTOMATIC
MIMIZD!
As I'm driving anywhere if it has to work harder going up a hill the service engine soon light just flashes.
Jun 13, 2021 at 8:38 AM
Good morning,
This could be plugs and/or ignition coils causing the misfire.
The light flashing indicates there is a misfire or one or more of the cylinders are not providing enough power.
https://www.2carpros.com/articles/how-to-change-spark-plugs
I would also do a compression test since the plugs are out to be sure there is no internal engine issue. You can rent a tester at a parts store. You should have 140-160 pounds on each cylinder.
Jun 14, 2021 at 12:59 AM
