Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
C1500
Engine
Symptoms
Rich
Third cylinder is missing and it is running rich?
1998 GMC C1500
305,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BUCKDM
MEMBER
1 POST
3rd cylinder is missing and it's running rich?
Oct 6, 2023 at 3:26 AM
Experienced Mechanic
If you have a misfire the system thinks the engine is running lean so it will increase the fuel input to its max. So, we need to fix the misfire and that part should go away. Let's remove the spark plug for inspection and replace it if needed.
This guide can help:
https://www.2carpros.com/articles/how-to-change-spark-plugs
If that does not help let's do a compression test.
This guide can help as well:
Please go over these guides and get back to us.
Oct 6, 2023 at 3:46 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
