missfire
120,000 MILES • 2.4L • 4 CYL • AWD • AUTOMATIC
GATOR63
not sure of mileage, but sometimes I get misfire code and at other times no codes I clear it. rough at idle no smoke new plugs. seems to run good going down the road but a idle rough but not always.
Mar 21, 2017 at 7:31 AM
CARADIODOC
  • 34,415 POSTS
How long since the spark plugs were replaced?
Mar 21, 2017 at 8:18 AM
STEVE W.
  • 15,419 POSTS
Clean the IAC valve and the throttle body. Also check for a vacuum leak. Doesn't take much to cause the IAC on that engine to get sticky and cause idle issues.
Mar 21, 2017 at 2:23 PM
