missfire #5
178,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
RAY1024
I have a 2002 trailblazer with missfire #5 I have replaced coil plug injector pig tail looked for crack in wires .I erase codes and comes right back I got a cm butt want to make s hure it will fix it before I spend the money to get it flashed. ..please help..
Jan 26, 2016 at 11:57 PM
HMAC300
  • 48,601 POSTS
check compression then have a pro freeze frame it to see if it's a sensor giving the problem as they will cause this. also check fuel pressure with a gauge auto parts rent it
Jan 27, 2016 at 1:28 AM
RAY1024
Ok ty for your help .what should the compression be
Jan 27, 2016 at 3:31 AM
HMAC300
  • 48,601 POSTS
anything over 90psi is good
Jan 27, 2016 at 3:59 AM
