Misfire cylinders 4, 5, and 6?
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
KHALEDYOUNES
I have a misfire 4,5,6.
I have changed sparks plugs, changed and reversed coil, changed all fuel injectors, and nothing changed. I checked on the m e of the car (brain of the car) and nothing unusual, but I noticed that when I unplugged the MAF the car ran way better than when the MAF is plugged in.
That's why I changed the MAF and the sensor and nothing changed.
What should I do next?
Thank you
Feb 5, 2023 at 5:38 AM
  • 110,246 POSTS
When you disconnect the MAF, the engine goes into a predetermined setting allowing the engine to continue running.
When you do this, does the engine run properly? Have you checked for engine vacuum leaks that can affect the MAF? If not, here is a link that explains how it's done:
Let me know if you find anything.
Feb 5, 2023 at 9:22 AM
KHALEDYOUNES
Hello Joe,
I forgot 2 mention that I am working on cars 2 years from now.
I did a smoke test to find for any leaks.
And no leaks were found.
So, I took it to a technician and told me the pressure in the engine is incorrect, but how can it be incorrect and when I unplug the MAF cars works 70% better.is that logical?
I am thinking of a bad catalytic converter.
What do you think??
Thank you
Feb 5, 2023 at 5:14 PM
  • 110,246 POSTS
What pressure in the engine was he referring to? Was it engine compression, vacuum, exhaust back pressure, or crankcase pressure?
Feb 6, 2023 at 11:59 AM
