2000 Mercedes Benz C280 Engine stalled twice and won't star
2000 MERCEDES BENZ C280
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
APIROGLU
My car stalled at traffic lights yesterday, restarted without a problem, drove half a mile, then gas pedal didn't work/engine stayed at idle, parked the car near the curb, and I think I stopped it (it probably didn't stall this time, though not sure), and tried starting it without success. Tried about 5-6 times in a row, nothing. Cranks but does not start. Then I opened the hood, tried listening to the engine although I don't know much about them :( But I don't know if it's normal, when the key is in position 2, there is a humming sound coming from the cables toward the windshield.
Fuel filter was replaced 5k miles ago by a friend, although I remember him saying that he used a non standard clamp for the filter.
I tried to start it again about 10 minutes later without success, and hasn't tried again after towing it back home.
update: I listened to the sound from under the hood again today, it's a loud humming sound or like a buzzing sound. I opened the trunk, listened to any sound there, after turning the key to position 2, waiting 5-6 seconds, another buzzing sound starts from inside of the fuel cap, or somewhere there.
May 4, 2009 at 2:33 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Need to determine oif loss of fuel or spark has occured. Pull plug wire hold 1/4 " from block crank spark? Next spray carb cleaner ioto intake crank does it fire?
Let me know
Thanks for donate
Also check engine light on?
May 4, 2009 at 9:10 AM
APIROGLU
[quote:9736ff9071="Docfixit"]Hi
Let me know
Thanks for donate
Also check engine light on?[/quote:9736ff9071]
Fuel is more than half tank full. There is no leak from fuel filter. My friend checked a few things, said gas is pumped without a problem. Tried jump starting, no luck.
Spark plugs are not conveniently located on a C280 engine, I couldn't manage to pull a spark plug, should I just yank it? And where is intake?
May 5, 2009 at 1:13 PM
