misfire with fuel cut off
106,435 MILES • 4 CYL • 2WD • MANUAL
GARY NICHOLSON
Hi, I have the car listed above SEI model. My car has a misfire, had it in garage had plugs and coil packs done. Essentric valve sensor, done rocker cover gasket done, timing chain done, rocker cover gasket done, mass air flow sensor checked for intake leaks with smoke test no leaks. Also injectors have been checked, but still misfiring cylinder one with fuel cut off. At a loss now to what to try so is my garage. Any help would be appreciated.
Jun 30, 2018 at 5:22 PM
  • 55,746 POSTS
No problem, we can help. Lets run the codes first to see what comes up.
Cheers, Ken
Jul 2, 2018 at 5:47 AM
