Miss fire code
200,000 MILES • 3.5L • V6 • 2WD • MANUAL
DILL-11
  • 126 POSTS
All new plugs and coil packs, still have a miss fire code. Can the catalytic converter be stopped up/ or could the timing chain have jump a notch? Or bad ECM? Please help!
Dec 30, 2017 at 2:47 AM
  • 31,937 POSTS
you should be doing a compression test first, if that is okay, check for vacuum leaks and make sure fuel pressure and injectors are okay. identifies the code for a specific cylinder or a random code?
Dec 30, 2017 at 6:46 AM
