Misfire
245,000 MILES • 8.1L • V8 • 4WD • AUTOMATIC
STEELEMAN63
Started up this morning and had a miss and when I revved it up it tried to clear up and then check engine light flashed twenty six times.
Jan 3, 2018 at 8:45 AM
  • 55,744 POSTS
This sound like you have a misfire which is probably caused by the spark plugs and wires that need to be replaced.
Here is a guide to help you:
https://www.2carpros.com/articles/how-to-change-spark-plugs
We should run the codes to see what comes up to confirm the issue.
Please run this test and get back to us.
Cheers, Ken
Jan 5, 2018 at 4:36 AM
