Misfire
200,097 MILES • 3.8L • V6 • 2WD • MANUAL
JOHN R. MASK
Hello, my car has lost power and acceleration. It runs like a bad fuel filter. i changed it, but still runs bad. i am also smelling fuel, but find no leaks and it is making my oil change light come on.
Feb 28, 2017 at 2:35 PM
  • 31,937 POSTS
check for a very wet spark plug, you may have a leaking injector, but also check that you have good spark at all plugs and the plug gaps are not excessive, start here.
Feb 28, 2017 at 5:18 PM
JOHN R. MASK
So could injector o-rings cause the problem. Oh and tonight it went back to normal for about two miles.
Feb 28, 2017 at 7:21 PM
  • 31,937 POSTS
no, normally if you have a leaking injector it is the internal pintal that weeps they need to be flow tested on a bench tester to see how well they are working.
Feb 28, 2017 at 7:24 PM
