Engine miss
103,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
LJBD
  • 12 POSTS
Have an engine miss cannot get rid of. New carburetor, pugs and wires cap and rotor. Still have the miss. Any idea what is the cause?
Sep 2, 2018 at 7:01 AM
AL514
  • 5,691 POSTS
Hello there, thanks for using 2CarPros.com. Are you noticing the miss at idle or driving? For a quick check you can try cleaning the throttle plates and do an inspection of any vacuum lines. Also, I see with the low mileage you have in the year of the car it must have been sitting for awhile. So check wires under the hood and look for any critters crawling around. Mice love to chew on wires. But some more information on the vehicle will help, any other symptoms.
Sep 2, 2018 at 10:50 AM
LJBD
  • 12 POSTS
Have the miss at thirty to forty mph. Is it possible it is a timing problem?
Sep 2, 2018 at 11:39 PM (Merged)
  • 110,248 POSTS
I think I just sent you information on timing marks. LOL Regardless, it could be a timing issue or several other things. Things such as fuel pressure, engine vacuum leaks, needing a tune up. Can all cause a misfire.
Here are a few links that may be helpful for you. Take a look through them and see if they help.
This link shows a newer car with OBD2,. However, read down through it and you will locate info on spark plugs, engine compression, spark plug wires.
LJBD
  • 12 POSTS
Where are the timing marks on a 1986 dodge colt 1.5 Liter. Trying to time with timing light. Cannot see other mark on pulley. Can you send picture if possible.
  • 110,248 POSTS
Hi and thanks for using 2carpros.com
I just went through my manual and found two pictures. I hope they are helpful.
LJBD
  • 12 POSTS
Where is the timing marks on the bottom pulley for timing. I cannot see one in the picture you sent or on the car. Do you have a clearer picture. Thanks.
Sep 2, 2018 at 11:43 PM (Merged)
RENEE L
  • 1,260 POSTS
Hello LJBD,
Thank you for using 2CarPros.com. If you have further questions on this issue please respond to this post thread instead of starting a new question. This way our experts are able to keep tract of the problem and the answers they have given you.
Thank you and have a great rest of your day.
Renee
Admin
Sep 2, 2018 at 11:45 PM
  • 110,248 POSTS
Hi. It should be in line with the crankshaft pulley locating pin. It is not a very big mark.
Sep 3, 2018 at 11:55 AM
