Misfiring issues
200,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
RODNEY HAMMONDS
Number and two and three cylinders are misfiring. I have changed the plugs and wires as well as the number two and three coil and the car is still misfiring. Also, have added Marvels Mystery oil to my gas as an enhancement. Check engine light is still on and still reading that cylinders two and three are misfiring. Do not know what to do?
Dec 30, 2017 at 5:42 AM
Good morning.
Possible issues:
1. low compression. You need to do a compression test on the cylinders to be sure the engine does not have internal damage.
2. head gasket. A failed head gasket will cause this as well. A leak down test will confirm.
3. Fuel injectors not allowing fuel or not being commanded to open.
4. PCM not turning on the injectors.
Dec 30, 2017 at 7:45 PM
