1998 Toyota Camry codes
THOMAS MALEY
  • 1998 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 61,000 MILES
Car has 5 codes, one for random miss three for random miss on cly's #2#4#6 then code po171
Thursday, August 26th, 2010 AT 8:45 AM
MMPRINCE4000
  • 8,548 POSTS
Misfires are generally plugs, but could be coil or fuel.
A 1998 (if it has original plugs) is WAY overdue for a plug change.
I would start by changing plugs and resetting codes.
If codes come back (especially P0171 system lean) then you will need to get fuel pressure checked and O2 sensor output.
Thursday, August 26th, 2010 AT 8:55 AM
THOMAS MALEY
THANK YOU, I'LL CHANGE PLUGS AND GET BACK TO YOU
Thursday, August 26th, 2010 AT 9:14 AM
MMPRINCE4000
  • 8,548 POSTS
Keep us informed.
Friday, August 27th, 2010 AT 8:22 AM
