Misfiring and codes P0302 and P0300
214,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
W I LLI AM
My car's engine is misfiring I get codes P0302 and P0300 usually at the same time. Really rough idle where it vibrates in the cab.
I changed spark plugs and spark plug wires and the airflow sensor and it ran better for a while where it would only give check engine once a week. Now it's every single day at least once it triggers check engine light, usually when accelerating. I took it to a shop and they couldn't find the problem but said the fuel pressure is okay and told me maybe its the fuel injectors not working properly.
What should I do?
Aug 31, 2020 at 6:20 PM
Good morning,
The first thing I would do is check the compression to be sure the engine is working good internally.
If the fuel pressure is good, then we need to check for codes. Can you give me all the codes that were listed?
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
You could try swapping the injector around for number 2 to another cylinder to see if the misfire goes to another cylinder. That will confirm the injector being the issue.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Aug 31, 2020 at 9:45 PM
