Misfiring and lean bank 1?
275,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
KWHYNOT
  • 5 POSTS
The symptoms started after a collision, but I don't think they are related because it wasn't a big hit. Damage was limited to the passenger side with the headlight busted out and the hood pushed back along with the hood mount bracket.
The issues started with the vehicle stalling a couple of times, while driving it at lower speeds. The following error codes popped up.
P0171
P0300
P0302
P0304
Indicating a lean condition and misfires on cylinder two and four
The following has been done:
MAF - ODB live data looks ok. I tested by checking the value at idle and then doubling the revs and the sensor showed double value. I also cleaned it with MAF cleaner
Air filter, plugs and coils have been replaced
O2 sensor appears to be OK based on the live data
Fuel pump hasn't been tested
I swapped the injectors around and then started getting a misfire on cylinder three, which suggested it was the injectors. I tried replacing them and still get P0171 and P0304. Don't read too much into P0302 missing because it has been inconsistent overall, and I may not have driven far enough for that one to pop up
I haven't performed a compression test or a smoke test to check the intake and vacuum hoses
My thought is this is probably not due to anything like the O2 sensor, fuel pump, or a vacuum leak because that should affect all cylinders equally. Maybe I'm wrong on this?
The only thoughts I have is to check the compression and maybe try a different set of injectors since it's possible the ones I tried weren't any good. And a smoke test if that doesn't prove anything.
I look forward to your input.
Dec 14, 2024 at 9:43 AM
  • 55,797 POSTS
A smoke test would be good to check the intake for leaks so that is where I would start, and if that is okay, I would check the fuel pressure.
Fuel pressure Standard fuel pressure 304 to 343 kPa (3.1 to 3.5 kgf/cm2, 44.1 to 49.7 PSI)
I must say as well the MAF sensor, even though it was cleaned, can still cause this problem. I would check the GPS reading and compare it to a new sensor. You will need to get a fuel pressure gauge from the auto parts store which you can rent for free or cheap to check the fuel pressure.
This guide can help out as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
I don't think it is the oxygen sensors. How does the engine seem to run? Can you upload a short video so I can see? Please let us know what happens.
Dec 15, 2024 at 3:07 AM
KWHYNOT
  • 5 POSTS
It is down in power and runs rough at idle. It has stalled several times, always when slowing to a stop or turn or when accelerating off of a stop. It is inconsistent, only having stalled a handful of times. I also noticed that it idles ok when first started but starts running rough when it comes off fast idle
Shouldn't a MAF, vacuum leak, fuel pressure, or O2 affect all cylinders? Is it more likely the misfire is causing the lean code? I doubt they are unrelated because they both popped up at the same time
I've included videos showing the ODB data and the engine bay. The roughness is subtle, so it didn't come through well. It's also not as rough as usual. When it's bad the RPMs can fluctuate from as low as 500 up to 1,200.
Dec 15, 2024 at 5:12 AM
  • 55,797 POSTS
Thanks for the video, it helps. The engine noise does not sound good, you may have a roller follower that has fallen apart. Also, the MAF sensor readings look low, I would do a compression test and check for vacuum leaks.
This guide can help:
and
It would be a good idea to remove the valve cover so you can inspect the valvetrain. Please upload more videos of any part you may have found that is questionable.
Dec 17, 2024 at 1:59 AM
KWHYNOT
  • 5 POSTS
I found the problem. A small hole in the intake manifold directly in front of cylinder four, the one that showed the most misfires. Given the way it only ran rough when it came off of fast idle and seem to be normal on the highway, my suspicion is that the hole was only big enough to make that cylinder misfire when there was low flow but in high flow it couldn't lean it out enough to make that much difference.
Dec 23, 2024 at 11:26 AM
  • 55,797 POSTS
Yes! good find, those plastic intakes can create weird problems like this. Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Dec 24, 2024 at 3:07 AM
