Flashing check engine light, misfiring, and flooding
190 MILES • 2.2L • 4 CYL • 2WD • MANUAL
SEWINGOPERATOR67
Check engine light blinking. Rough idle, extreme use of fuel. Fuel coming out of spark plug, stalling, no power when pulling a hill. replaced plugs and coil pack. The car will start. May have gotten bad fuel on last fill up.
Dec 14, 2021 at 11:03 PM
Good afternoon,
You have an engine misfire causing the light to flash.
There is most likely a code set for the misfire identifying the cylinder.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
I would start by checking the compression to be sure the internals of the engine are good. You need 140-160 pounds.
I would also verify the fuel pressure to be sure sufficient fuel is flowing to the injectors. You can rent a tester for checking the pressure at a parts store.
I attached a guide for you as well.
Dec 15, 2021 at 4:02 AM
