Misfiring, what is the coil pack firing order?
154,821 MILES
EMMANUELNGANDU
  • 29 POSTS
We changed the injectors, fuel pump, spark plugs and high-tension cables, still it's misfiring. kindly asking for the coil pack firing order.
Apr 14, 2022 at 7:17 PM
SQM
  • 6,383 POSTS
I have attached the coil pack firing order along with the cylinder locations.
Apr 15, 2022 at 1:03 AM
EMMANUELNGANDU
  • 29 POSTS
Thanks, I followed the firing order you gave me it performed better than before, now it's showing a p1668 code.
Apr 16, 2022 at 7:14 AM
SQM
  • 6,383 POSTS
The P1668 is an anti theft code, typically gets triggered due to an issue with the alarm.
I have attached some helpful info on the code below for your reference.
Apr 16, 2022 at 3:50 PM
EMMANUELNGANDU
  • 29 POSTS
I have south Africa Isuzu mpfi kb240 engine number C24SE, engine light came on when I press the gas pedal and goes off when I let go off the pedal, what could be the problem?
May 1, 2022 at 4:06 AM
SQM
  • 6,383 POSTS
Since this is on a different vehicle, kindly open a new thread. This is put the question in front of all the experts.
Simply go to this link and ask the question:
May 1, 2022 at 4:39 AM
EMMANUELNGANDU
  • 29 POSTS
Alright, thanks.
May 1, 2022 at 5:45 AM
SQM
  • 6,383 POSTS
You are welcome.
May 1, 2022 at 12:24 PM
