Misfiring
169,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JR LAWRENCE
Will start stay running, does not have full power and sounds like it is misfiring.
Nov 7, 2018 at 10:38 PM
BMDOUBLE
  • 1,139 POSTS
Have you retrieved any dtcs? If not, you will need to have this done to begin the diagnostic process. Of course you can also do a quick visual under-hood inspection like checking your air filter housing and filter are clean, clear and fastened correctly. Also fuel level and condition can play a role in a rough running vehicle. By having codes read you can isolate the problem cylinder and find a possible faulty coil, spark plug, injector or engine mechanical concern.
Nov 8, 2018 at 1:12 AM
RENEE L
  • 1,260 POSTS
Hello JR LAWRENCE,
If you decide you would like to conduct the scan yourself here is a link to an article from this site that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us with the code number(s) so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Nov 9, 2018 at 7:41 AM
