Engine begins to misfire after warming up?
160,000 MILES
SBROWN0903
Could it be an ignition coil?
Mar 23, 2023 at 8:04 AM
  • 110,248 POSTS
It certainly could be a coil. It also could be several different things. For example, a failing crankshaft position sensor, a fuel pressure issue, a partially clogged catalytic converter, an engine vacuum leak, and so on.
By chance, have you had the computer scanned to narrow down the location of the misfire? If you haven't, I suggest it.
Here is a link explaining how it's done:
If you don't have a scan tool, most parts stores will do it free of charge. Have that done and let me know what is found.
In the interim, here is a link that explains how to locate a vacuum leak. Take a look through it and check under the hood to see if you see anything disconnected or damaged.
Mar 23, 2023 at 11:44 AM
