Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Commander
Engine
Symptoms
Idle Rough
Misfiring
2006 JEEP COMMANDER
216,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ZETHWOO
MEMBER
1 POST
Rough idle rough idle and skipping.
Nov 20, 2020 at 7:19 AM
Experienced Mechanic
We need to do a couple things to start. First, run through this guide on the basics of misfires.
Then we need to check codes to see which cylinders are misfiring.
Then we need to check for vacuum leaks and make sure that is not causing any issues.
Once we check for these things we should have a pretty good idea what to do next. Thanks
Nov 20, 2020 at 9:15 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
