My car started misfiring a few days ago. It starts jerking like it is not getting enough gas. What could be the problem?
Apr 20, 2018 at 12:27 AM
✓Experienced Mechanic
Good afternoon.
There are many possibilities for a missfire.
1. spark plugs worn.
2. ignition wires arcing out from open areas.
3. low engine compression especially in one or more cylinders.
4. injectors becoming clogged or solenoids have too high resistance..
5. wiring issues to and from the injectors.
6. mechancial issues internal in the engine such as camshafts worn, rockers or lifters.
Apr 20, 2018 at 4:08 AM
NHERNANDEZ1405
MEMBER
Thank you for answering my question. I will have someone look into these options.
