Codes are p0300, p0301, p0302, check engine light flashing, loss of power, and misfires when idling
227,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
KMOATS48
Missing during idle and shakes when accelerating on a hill loss of power check engine light on flashing when accelerating rough idle at stop in gear.
I’ve replaced coils, spark plugs and wires, mass flow sensor, now thinking about cam and crank position sensors. Not sure how many oxygen sensors there are. And I put a can of injection cleaner in the tank, what next? Codes are 300,301,302.
Suggestions please!
Jun 12, 2022 at 7:26 PM
BORIS K
  • 836 POSTS
Cam and crank position sensors as well as oxygen sensors will not cause a misfire on just two cylinders on opposite banks. Cylinder one is on bank 1 and cylinder two is on bank 2. see image 1 below.
As you already have swapped coils and spark plugs this leaves us compression, injectors, or a possible air leak at the intake manifold.
Next, I would check if the injectors had the correct internal resistance.
Using a digital voltmeter set to ohms test the injectors for a resistance value of between 13.4-14.2 ohms at 20 degrees C/68 F.
How to use voltmeter:
How to test coils and injectors for your vehicle see good video below:
https://youtu.be/-oAeZfr4OxI
With a good diagnostic tool, you will be able to display the misfire counter, to prove that cylinders one and two are misfiring.
Hope this helps.
Cheers, Boris
Jun 13, 2022 at 2:07 AM
KMOATS48
I found a bad vacuum line will this cause my problem. Picture 3 what is this looks like a vacuum line?
Jun 14, 2022 at 2:34 AM
SQM
  • 6,383 POSTS
Yes, a bad vacuum line can trigger loss of power and make the engine run rough.
So that should be the first item that needs to get fixed.
As for the third picture, it does not appear to be a vacuum line. Can you tell me exactly where it is located? Maybe take another picture from a different angle.
Also is there any fluid coming out of it?
Jun 16, 2022 at 12:55 PM
KMOATS48
It is next to the oil filter behind the exhaust manifold looks like a blow by tube there is a number 8. Couldn’t find it anywhere online and can only get a picture from the one side. Just curious what it does and thank you for the help, I am going to keep nickel and diming myself fuel filter and PCV valve maybe O2 sensor this week until I can get a compression gauge.
Jun 16, 2022 at 2:13 PM
SQM
  • 6,383 POSTS
With the engine running, does it have any suction? or any fluid comes out of it?
Jun 16, 2022 at 3:07 PM
KMOATS48
It’s not running right now; I have a few things dismantled. here’s another picture of my mystery part.
Jun 20, 2022 at 1:04 PM
SQM
  • 6,383 POSTS
This could be a pressure relief valve. That is what the little tube appears to be a drain.
The catalog does not show any location for that part.
Jun 21, 2022 at 2:58 PM
