This car sat in a garage for several years prior to trying to fix the problem, when this car was parked it ran perfect. The car would start and misfire on several cylinders. All injectors were changed and they have good spray patterns now, A compression test was performed and all seemed normal, a leak-down test was performed and two have poor numbers, one is 60/90 and one is 75/90. The mechanic feels that it probably has some stuck piston rings. I realize that this is not good but would poor leak-down cause a misfire when it has good compression?
Aug 23, 2017 at 8:58 PM
