Misfire/rough running?
212,176 MILES • 2.2L • 4 CYL • 2WD • MANUAL
JSTRASSBURG89
The truck was running pretty rough. I took it to a mechanic, and the guy said it was skipping. He replaced the spark plugs, wires, and coil packs. The plugs were terrible. I got the truck back, it does run better, but still running really rough. Especially at low RPMs and under load. I heard that I should check vacuum lines, but I only know the basics of keeping a car running. Oil, brakes, tires, starters... anything else and I'm kind of in the dark.
Sep 11, 2023 at 2:12 AM
  • 55,628 POSTS
It sounds like you have low compression in one or more for the cylinders.
Here is a guide to help you and confirm the issue:
Please go over this guide and get back to us.
Sep 12, 2023 at 3:23 AM
