Misfire, code PO301
140,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RANDY1955
  • 71 POSTS
A misfire number 1 coil on plug.So I thought maybe coil so I swapped 1 to 2 cleared code and it went to no 2.I bought a new coil.The same misfire in number 2.Cleared code put 2 back to 1 misfire number 1.So does any one have any experience on this?Thank you
Nov 21, 2019 at 11:13 AM
  • 110,248 POSTS
Is it possible (and I realize unlikely) that you got another bad coil? Try switching it with cylinder 3 or 4 and see if the misfire follows the coil. If it does, try yet another coil.
Let me know. Based on the description, I feel the same as you. It doesn't make sense.
Also, let me know if there are other codes that showed up.
Nov 21, 2019 at 11:20 AM
  • 55,746 POSTS
Did you try changing the spark plug? this can make the coil seem bad to the computer. Here is a guide to help:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Nov 21, 2019 at 12:31 PM
RANDY1955
  • 71 POSTS
Posted this before need some help it still goes to what ever cylinder I switch to.Bought new coil no change so what else could it be?
Dec 6, 2019 at 6:51 AM (Merged)
RANDY1955
  • 71 POSTS
I posted this the other day can any one give me a direction to go with now bought new coil same problem whatever I switch it follows,coil on plug the coil is good to.
Dec 8, 2019 at 4:43 AM (Merged)
