Misfire on half of engine
160,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
JAMES JAMES
Driving downhill, began to shudder and lost power. Stalled and would not start. Pulled codes, p0106, p0300, p0304, p0305, p0306, p0340. I replaced the CMP, and it did not help. What else would cause half the engine to not work?
Feb 15, 2018 at 12:36 AM
STEVE W.
  • 15,418 POSTS
Well the P0106 is the MAP sensor which would effect the entire engine. However, with the P0340 and one side of the engine giving misfires I would start by pulling the cam sensor back out and verify that the cams are actually turning as a failed timing chain could easily cause all but the MAP code. Or do a compression check on those cylinders and see if you get anything.
Feb 16, 2018 at 11:53 AM
