Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Cherokee
Engine
Symptoms
Misfire
Misfire on cylinder two
2000 JEEP CHEROKEE
214,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
BAD TO THE BILL
MEMBER
1 POST
I have changed plugs, coil pack, injectors and MAP sensor, but still have a misfire on cylinder two. any suggestions ?
Feb 19, 2020 at 5:06 AM
Experienced Mechanic
Good evening,
I would check the compression to be sure there is no internal engine damage.
I attached the procedure and the spec for you to check.
Images (Click to enlarge)
Feb 19, 2020 at 7:44 AM
BAD TO THE BILL
MEMBER
1 POST
I’ll give it a try and let you know what happens. thanks
Feb 22, 2020 at 2:44 AM
You are welcome.
Always glad to help.
Keep us updated.
Feb 22, 2020 at 12:06 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
