Misfire on all cylinders and code p0300
2012 CHEVROLET CAMARO
172,000 MILES • V6 • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
I am debating whether to take a chance on this car and buy it. it's in good shape overall, check engine light on, shows misfire on all cylinders plus p0300, not running rough that bad actually. it also has a camshaft code that I cannot remember the code right now. is it possible for a camshaft code to cause it to misfire on all? is this something common that you seen on these cars?
May 10, 2020 at 5:17 AM
Good afternoon,
The most likely cause is low fuel pressure causing this issue. There is not enough fuel in the rails for proper fueling.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
I would have that fixed first before committing to a purchase. Whoever is selling already knows what is wrong and sounds like they do not want to fix it.
Yes, it is a deal breaker.
May 10, 2020 at 7:57 AM
