1996 Chevy Camaro code p0372
1996 CHEVROLET CAMARO
153,000 MILES • V8 • 2WD • AUTOMATIC
WILDBILLZ28
what is code p0372, how do you fix it
Jul 16, 2010 at 3:21 PM
HMAC300
  • 48,601 POSTS
this is best checked by a pro. it could be a myriad of things it can be anything from a bad ground to a bad distributor to a bad pcm. You shouldn't go replacing things to fix it when it may just be a bad vent to the distributor. this has to be diagnosed using the freeze frame function on a scan tool to try to weed it out.......
Aug 8, 2010 at 1:07 PM
