Misfire cylinder three and code p0303
136,000 MILES • 4.3L • 6 CYL • 4WD • MANUAL
JCANIZZO8
Changed plugs,cap and rotor and new distributor. Truck starts but still has miss in cylinder three. Coil changed,no change in misfire. Lean code p0303 still persists. Pulled number 3 spark plug wire off distributor, no change in engine. I popped the fuel rail and got good fuel pressure. Engine starts fine and has no power,just a misfire that I cannot find source of. No vacuum leaks.like I said,pull number 3 wire and no change in engine. it is not getting spark only on that cylinder. Is it cam position or crank position sensor, PCM?
Dec 29, 2019 at 2:44 AM
Good afternoon,
Did you check the compression on that cylinder? I would start there.
Dec 29, 2019 at 3:44 AM
JCANIZZO8
Yes,is at 75 psi.
Dec 29, 2019 at 8:46 AM
Okay. That is the issue. You need at least 140 to 160. That is why you have the misfire.
Dec 29, 2019 at 9:00 AM
JCANIZZO8
Thanks.
Dec 29, 2019 at 11:44 AM
You are welcome.
Always glad to help.
Dec 29, 2019 at 8:46 PM
