Misfire, oil in two spark plug wells
100,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MFILLEY81
Everything under the hood is new except for the motor itself. Even the cylinder head is new. We had the motor remanufactured twice. It was running good and then it lost all power, the check engine light started flashing and it would barely move. I checked the spark plus and two of them had oil on them. Is this a o-ring problem, a piston ring problem or a head gasket problem?
May 16, 2021 at 11:26 PM
  • 55,627 POSTS
Can you upload a picture of the spark plugs? it sounds like the head gasket blew between two cylinders. to be sure lets do a compression test. this guide will show us how:
This guide can help as well:
May 18, 2021 at 2:42 AM
