Misfire in park when gas I pressed
208,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JORTIZ2001
Misfire in park when gas I pressed and held down. What could be wrong? Thanks.
Sep 1, 2021 at 8:18 AM
SQM
  • 6,383 POSTS
You will typically get misfire due to having faulty spark plugs.
Does it misfire when you accelerate in drive? or only when parked?
Usually with a misfire the engine light gets illuminated. Is your engine light on? If you scan for the codes as it can help diagnose the issue.
Please let me know little bit more information.
Sep 1, 2021 at 1:59 PM
