misfire cylinder four
2008 CHEVROLET TAHOE
190 MILES • 5.3L • V8
SHERMAN SIMMONS
25 psi in cylinder, engine running rough and gas smell.
Oct 2, 2020 at 5:51 AM
Good afternoon,
This reading indicates you may have either burned valves or bad rings.
https://www.2carpros.com/articles/the-reasons-for-low-compression
https://www.2carpros.com/articles/replace-engine-piston-rings
The heads will have to removed to determine the failure.
Oct 2, 2020 at 9:36 AM
