Misfire cyl. 1 , high STFT?
115,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
TOTALMC
  • 117 POSTS
Just replaced spider injectors with the upgraded injectors
Can still feel a slight misfire at idle and while driving
I'm getting a misfire on #1 , and STFT starts in range , but then moves up to 25%
New wires and plugs , smoke test shows no vacuum leaks , also not finding any exhaust leak
I'm going to try cleaning the MAF , swap plug wires to see if one is faulty , along with verifying the cap and rotor are Ok .. guess I'll check the fuel pressure while I'm at it
do not have equipment to perform leak down test
IS THERE SOMETHING ELSE I'M MISSING ??
Thanks for any and all thoughts
Nov 13, 2025 at 4:02 AM
TOTALMC
  • 117 POSTS
CEL started flashing while driving .. going to hook up my scan tool and record , will update findings
Nov 14, 2025 at 1:38 AM
TOTALMC
  • 117 POSTS
UPDATE
I cleaned the MAF , installed new cap / rotor , checked resistance on plug wires and verified I was getting 60 PSI fuel
STFT numbers Bank 1 have fallen more in line , 0- 10 .. LTFT now moves about as fast as the short-term from 10 - 18 , when it was below 10 all previous tests
And now bank 2 is showing negative fuel trim -10 to -20 , where as it was fine an hour before during the test drive before replacing cap and rotor
To top it off it now is throwing a p0300 random misfire , where it was just a 301 all previous times
I'm going to double check all my work next time
When I was just chasing the #1 misfire , I was thinking the injector tip may have been clogged while installing the new spider ??
.. while watching live data , 02 voltage and STFT seem to look just fine , wasn't seeing a rich condition , and they were moving in conjunction with each other as they should .. wouldn't that mean that there is not excess fuel making it through ??
Any thoughts or ideas are greatly appreciated
Nov 14, 2025 at 8:47 AM
  • 55,612 POSTS
Yep, I would remove the #1 spark plug and see what it looks like, (light or dark color) this can help tell you if the injector is not spraying correctly, Also I would do a compression test to see if it is low, this guide can help
So if the compression is low it will misfire and cause a lean condition which will cause the STFT readings you are seeing. Also, make sure the plug, plug wire, cap and rotor are in good shape, can I ask if the injector was an AC Delco unit? Also, if the engine is in good shape I would get a new MAF sensor. Cleaning it sometimes can make the problem worse.
Nov 15, 2025 at 1:45 AM
TOTALMC
  • 117 POSTS
Update
Compression test showed even over all cylinders
Installed new plugs after taking compression test
New cap , rotor and wires
Smoke test showed no vacuum leaks
Not seeing any exhaust leaks
Replaced downstream 02 sensor , but it's still steady .035 .. for the first minute it read about 2.5 , but then fell back to a steady .035
All live data readings look normal , except for STFT B1 at +15 ..
The replacement spider was an upgraded aftermarket unit .. the only thing I can think is that it's faulty , and maybe I should switch back to an original style spider with the poppets
This one's got me scratching my head , any and all help is greatly appreciated
Dec 19, 2025 at 8:15 AM
  • 55,612 POSTS
Yep, the system is trying to richen up, I would get an AC Delco part to help fix the problem. Also, I would remove the EGR valve and check it for leaks, this video can help
https://www.youtube.com/watch?v=DqUCbbKdWf4
Please go over this guide and get back to us.
Dec 20, 2025 at 3:39 AM
TOTALMC
  • 117 POSTS
Ordering a new Delco spider , and will recheck EGR during the swap
Thanks again for all the diagnostic help
Will update next week
Dec 21, 2025 at 1:23 AM
  • 55,612 POSTS
Sounds good, that should fix it, please let me know, happy holidays!
Dec 22, 2025 at 1:23 AM
TOTALMC
  • 117 POSTS
Looks like original Delco spiders are unavailable , but I was able to pick up a remanufactured original style unit
Problem is finally solved .. for some reason , none of the upgraded spiders worked properly , the spider I just removed was never firing on cylinder one
Going back to the original poppet style seemed to do the trick , truck should be good for another 100k
Thanks again for all the advice
Jan 28, 2026 at 10:57 AM
  • 55,612 POSTS
Yep, good fix, I only use AC Delco when it comes to the spider injectors. Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jan 29, 2026 at 12:59 AM
