Misfire cylinder number six, will not run
116,134 MILES • 3.6L • 6 CYL
MRTEEHALL
Starts. Rough then shuts off two seconds later. I had a p0206 code. Replaced coils and spark plugs and injectors. The vehicle ran great before the repairs
Jul 2, 2018 at 2:37 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It sounds like you are having a problem with cylinder number six injector. The code P0206 is a code describing number six control circuit. In your post you stated you replaced that cylinder injector. Since the symptom is persistent/still there I suggest using a Noid light set to check injector pulse for that cylinder. Basically you unplug Injector harness at the Injector and the Noid light is plugged into the harness. The Noid light itself will be for GM vehicles and is clear plastic with a sight bubble. When vehicle is started and running if the harness is functional you will see a light flashing in the bubble to verify the injector signal is working. No light flash indicates a problem in the circuit and the Injector is not being fired. I can send more information and diagrams if needed when test completed. Hope this helps and feel free to ask any questions if needed.
Danny-
Jul 2, 2018 at 4:04 PM
