Misfire code, car shaking a little
130,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DANA ALMOKDAD
Cylinder four compression is 70.
All other cylinders between 90-95.
The car misfiring after head gasket job.
Timing chain kit has been replaced.
There is a tiny space between the camp exhaust locking tool and the camp intake.
Mar 3, 2019 at 1:18 PM
SCGRANTURISMO
  • 4,897 POSTS
It looks to me like compression is low in all four cylinders. I have included a compression pressure chart for your vehicle down below in the diagrams. Your vehicle should have between 130 - 195 PSI in all cylinders. As a general rule of thumb, compression in lowest cylinder shouldn't be less than 10% of the highest cylinder. I have also included a link for you down below. Please go through all the information and get back to us with what you find out.
https://www.2carpros.com/articles/the-reasons-for-low-compression
Thanks,
Alex
2CarPros
Mar 3, 2019 at 2:43 PM
JIS001
  • 3,412 POSTS
I agree. All cylinders read really low? Where did you get your compression guage from? Also, can you provide the exact codes? With those readings I am surprise your vehicle even started? Let us know please.
Mar 3, 2019 at 3:01 PM
