Misfire code
114,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MC2
Car has been running rough at low speeds. At first I thought the CVT transmission was not down shifting, but ruled that out after taking to transmission shop. I was told that the crank sensor was bad and needed a tune up. Showed occasional misfire on cylinder two prior to changing all plugs and coil packs. Now car runs like a dream when first started and cold, but after fifteen minutes it starts running rough and now shows cylinder one misfire. Is it possible to get a bad coil pack? Are there any other reasons that the car would start misfiring after the engine warms up? Water and oil are good and show no signs of mixing, did a radiator pressure test and had no problems.
Aug 16, 2018 at 4:03 AM
STEVE W.
  • 15,409 POSTS
Yes it is very possible to get a bad coil or even a bad plug straight out of the box. Even more common if they are not factory parts. Easy way to test is simply swap the coil to a different cylinder. If the miss moves with the coil it is defective, if not is is likely the plug.
Aug 16, 2018 at 4:34 AM
