Good evening,
303 is a misfire for number three cylinder.
Some possibilities.
1. Plug
2. Wire
3. Injector malfunction
4. Vacuum leak
5. Low compression
6. Valve train damage
7. Failed PCM from not signalling injector to fire.
I would start by checking compression.
P0303
Descriptor
Probable Causes
Evaporative Emission (EVAP) System
Evaporative Emission (EVAP) System Canister Purge Valve
Fuel Injector 3
Fuel Pressure Incorrect
Ignition System
Mechanical Engine Failure
Vehicle Running Out of Fuel
Dec 7, 2018 at 7:13 AM
